projected width in corridor mode single line
Can anyone explain me the reason why, in corridor mode - single line, the projected width of the survey area on the ground don’t change if I modify the flight eight?
thanks
Hi avincis,
Does this issue pertain to PIX4Dmapper or are you talking about PIX4Dcapture Pro, our flight application?
Hi, both on the PIX4Dmapper website and in the PIX4Dcapture Pro application. I planned the mission with the Pix4DCloud Advanced Mission Planner service on my PC and the problem appeared immediately. I then tried to import the mission to the Pix4DCapture Pro mobile application and the problem persists. The width is 10 meters at every flight eight (GCP changes regularly). It happens even in new plans built directly on Pix4DCapture Pro
