Hello
Can someone plz help me in Corridor mapping. How can i make project with 70% overlap on both sides.
I am using phantom 4 pro v2.
Regards
Rohit kumar
Hello
Regards
Rohit kumar
Please suggest me how can i use the app for Drone flying for Corridor mapping
Hello Rohit,
If a dual-track image acquisition plan is not possible, a single track image acquisition plan can be used if the overlap is high enough (at least 85% frontal overlap) and Ground control points (GCPs) are defined along the flight line in a zigzag pattern. For more information, please refer to the link below.
Corridor mapping
Number and distribution of ground control points (GCPs) in corridor mapping
The links below explain the mission types one can use with Pix4Dcapture and the steps to follow.
Types of mission / Which type of mission to choose
Pix4Dcapture - Getting Started
Kind regards,
In the given links it shows abt the GCP. That how to mark the GCP’s
I need a line flying as per my alingment. Because the alignment never goes straight. It will bend somewhere and there i hope we need a line flying as per the curve of the Road/Railway alingment.
Hello Rohit,
You may want to create several polygonal missions for the project that can cover the curved line. Unfortunately, Pix4Dcapture does not have a Linear Flight Plan option currently. I reported your need to our product manager to give more weight to this functionality.
