I am running intro a problem processing images taken with Sequoia. When I selected a Rapid “Initial Processing” all the images are calibrated and the quality report looks completely fine. However, when I switch to Full “Initial Processing”, most of the cameras are not calibrated and the error e0046: “Processing failed. No calibrated cameras.” comes up.
It might be because of the flight path (the Sequoia was mounted on a fixed wing), and the overlap set to 80% and 80% sidelap. However, the turns could have affected the final overlap and sidelap (look at image below). Nonetheless, it is very strange that Rapid processing will succeed while Full processing will fail to calibrate all the cameras.
Any idea on what could be causing this?
