I have been flying an Inspire 1 with cameras from Aerial Media Pros. We have an NGB camera and RGN camera. I can process the images but haven’t been able to produce an NDVI from the images. Can someone help me out?
Dear Robyn,
Pix4Dmapper can use modified cameras to produce NDVI maps. Please be aware that the channel names do not change (in most cases) so they will still be called R G and B. However, it is possible to change this in the mapper (the camera manufacturer should be able to tell you which band information is written in which channel). You can edit the band names here
and find out more about the Precision Agriculture workflow in Pix4Dmapper here
