Processing Issues with SODA camera
Running eBee, eMotion2 (for this particular flight), and Pix4D
We keep running into the same issue- we run stage 1. Initial Processing (rapid) and our data comes back normal. See below:
And:
However, when we go to stage 1.Initial Processing and choose Full, everything goes wrong.
And we are completely at a loss as to why. Any help would be appreciated, and more information can be provided if necessary
Hello Leah,
Have you upgraded the S.O.D.A. firmware? If you have not upgraded the S.O.D.A. firmware you can also try to process the images with the old firmware (1.1.0).
You will find instructions here: https://community.pix4d.com/t/3832.
Thanks for your quick response! We were able to process without any issues now.
