Pix4d process is getting stopped abnormally for lot of the datasets
(Mainly for large datasets above 4 GB)
Attaching the end of pix4-dmapper.log file
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: Updating /tmp/jobs/job-19752/working/swamp2/2\_densification/project\_data/swamp2\_group1\_densified\_point\_cloud\_part\_3.p4b
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: \>\>\>Constrain point cloud\<\<\< done in 500ms / 0.00833333 min.
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: \*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: \*\*\*\*\*\*\*\*\*\*\*\* generate textured mesh \*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Processing]: Substep Dense outputs finished.
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Processing]: Substep Dense mesh creation started.
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: Running Screened Poisson Reconstruction (Version 6.11)
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: ---------------------------------------------------------------------------
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: Parameters for poisson surface reconstruction
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: voxelGrid = \<\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: depth = \<12\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: fullDepth = \<5\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: voxelDepth = \<-1\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: cgDepth = \<0\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: scale = \<1.1\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: samplesPerNode = \<10\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: pointWeight = \<4\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: iters = \<8\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: threads = \<8\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: confidence = \<no\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: normalWeight = \<no\>
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Processing]: Poisson Surface Reconstruction
[2016.06.29 03:07:01][52%RAM][ 6%CPU][Info]: Poisson Surface Reconstruction [0/6] elapsed 000ms ...
[2016.06.29 03:14:25][70%RAM][ 6%CPU][Info]: [PoissonRecon] Step completed, 66% RAM
[2016.06.29 03:14:25][72%RAM][ 6%CPU][Info]: Poisson Surface Reconstruction [1/6] elapsed 07m:23s:608ms ...
[2016.06.29 03:15:13][73%RAM][47%CPU][Info]: [PoissonRecon] Step completed, 73% RAM
[2016.06.29 03:15:13][73%RAM][47%CPU][Info]: Poisson Surface Reconstruction [2/6] elapsed 08m:12s:122ms ...
Pix4d process just stopped here, and then Error code 137 thrown by the Java Command line executor
Exactly the same issue has been observed for 6-7 different datasets
This looks like the issue fix mentioned in Release 2.1.57. but doesn't seems like it has been fixed.
It would be great if this issue gets attention as soon as possible.
