Preferences / Processing Template / User Profile
There should be a way to set up preferences such as:
-What Coordinate System is default
-What colors I want to assign to classifications
-ft vs meters
-Ortho prefs - tif vs jpg
-Whether the sky is on or off by default
Instead of just selecting a processing template, I should be able to save the existing settings to a new template. Similar to Mapper.
Hi @Chris_Putnam
Agreed! We’re planning to address the need for “custom templates”, I would see all the export preferences there, but based on current estimates it will not fit into this year’s roadmap. That said, we have identified this need and will address this eventually.
As for preferences, we do have a preferences menu under Edit > Preferences. For now we have the default color for the background, whether you want to basemap to be displayed as well as the notifications settings for preview releases (I encourage you to subscribe to get all the newest developments! we release every three weeks). In this menu, we could add whether we’d like the sky option to be enabled, ft vs meters.
For the default CRS, I would like to have better default recommendations (pre-fill) of the CRS dialogs, so that you only need to “approve” instead of selecting from scratch. Would that work for you too?
@Pierangelo_Rothenbuhler,
"For the default CRS, I would like to have better default recommendations (pre-fill) of the CRS dialogs, so that you only need to “approve” instead of selecting from scratch. Would that work for you too?
Yes. That would be great. It would also be great if all Pix platform products would save preferences as a profile choice. Ex:
-Custom Classes (Name, type, color)
-GCP colors and sizes
-Line color and weight
-Breakout windows (requested in a separate post) and their location on multi-monitor setup
I hope this is helpful.
Thanks @Chris_Putnam
We’re planning to add a way to select a default CRS. As for the other defaults, that’s an interesting idea. I’ll keep it in mind for the future.
Just wondering if there has been any update on this feature?
Are we likely to get the ability to save processing templates soon?
Scratch that, found that this feature was implemented in 1.71, and we were still running 1.63.
However, now that we’ve updated and started playing around with the template manager - we’ve hit a problem;
When saving a template, it also saves the export folder and file names…
meaning every project will always export to the same folder with the same names, essentially overwriting the files with every new project run.
I did manage to find a work-around for this;
By exporting the template to a .json, and then editing this in notepad, I removed any mention of a folder path or file name (example: line that was “path”: “C:\Users\Public\Projects\filename.las”, becomes “path”: “”,)
re-importing this template seems to have fixed the issue, at least temporarily, but if anyone updates and saves over the template again, it will once more have saved the filepaths and filenames.
@aus-bd-survey, it’s great that you upgraded PIX4Dmatic. It’s important that you do it once in a while to ensure you benefit from the latest features, such as saving and managing processing templates.
The file path issue is a known issue that we are hoping to solve very soon. In the meantime, thank you for sharing your workaround which may be useful for others. We’ll post here once the bug is resolved. Cheers
We’ve removed file paths from processing templates last year, so you should not be running into your latest issue anymore. Let us know how it goes! Cheer
