It would be great to be able to:
-save user-defined colors for classes
-undock windows and save the user-defined layout so that multiple monitor setups can take advantage. Similar to Adobe Products.
-save different tolerances for color selection by user-defined name for quick filtering.
Thank you for your feedback, @Chris_Putnam,
I forwarded the first two pieces of feedback to the product team.
Regarding the third one, could you please elaborate on what you are trying to achieve? Could you share some examples for us to understand better?
The end goal is that it would be saved as a certain filter that can be used on the entire point cloud. Ideally, the user would be able to select a group of points that they want to filter and assign to a class. Based upon the selected points the software would then find other points that match the selected points, allowing for lower tolerances and more efficient filtering. Saving those colors as a template (ex “Vegetation Filter”) would help with multiple projects with similar color profiles.
Does that make sense?
Thank you @Chris_Putnam for the additional information.
I will pass this to the product team.
