is it possible to export points clouds related to individual images by pix4d?
best regards,
Maryam
best regards,
Maryam
Hi Maryam,
May I ask why you would like to export point clouds from specific images? I mean what is that you are trying to achieve in order to be able to assist you better.
You can classify the point cloud and put areas in the disabled group. I guess you can also disable images after step 1. This means point cloud is generated from specific images.
Moreover, editing the point cloud allows to clean the 3D model by reducing noise and improving the precision as well as the visual rendering.
These three articles could be helpful if this is what you are looking for:
Menu Process > Run Point Cloud Classification
How to generate the point cloud classification
How to edit the point cloud in the rayCloud
Nikoleta
