Point Cloud error - black hole
Hi!
First time this happened in a project.
Initial processing seems to work great.
grafik
Quality Report seems fine too:
grafik
grafik
BUT big black hole in the Densified Point Cloud and therefore of course a blurry Ortho und DSM with hole.
grafik
grafik
Summary
FILES
Report_Phil.pdf (2.0 MB)
Logfile_Phil.zip (537.9 KB)
Best Regards,
Phil
Hi @Phil,
Thanks for your quality report.
My best guess is that your point cloud show these holes because there is lack of matching:
As you can see it here in many areas there are not connections/matching between the different cameras which results in many blocks (6 in your case).
I would try with these processing options:
Step1
Image scale on 1/2
Rematch “Yes”
Step2
Minimum number of matches on 2
This should already improve your point cloud.
Let me know if it worked.
Best
