Hi there,
I’m currently trialing pix4d and wondered if once we’ve edited the point cloud to remove unwanted items, is there a way to refill the textures in so we dont end up with gaping black holes?
thanks in advance,
zoe
Hi there,
thanks in advance,
zoe
Hi Zoe,
In order to get outputs where there are no gaps caused by the removed points in the densified point cloud, you would have to generate a new point cloud by processing step 2 (this overwrites the whole step 2 results folder), then step 3. In order to keep the modifications you have done in the point cloud, you need to work on two separate copies of the project:
