After running processing #1 and #2, I edit the point cloud for un-wanted points. Equipment, Trees, ect. Once this is done, I run step 3 and create a *.DXF file for use. I’ve noticed that after the *.DXF is open, the areas that I cut out in the editing process are showing up like they have not been edited.
Running the latest 2.1.53 64 bit. New user!
Anyone else having problem? Any solution?
