can anyone help resolve this issue? the point cloud generated data farther out than the ortho. the images calibrated but the ortho cuts them off.
Hi, can you send:
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf
Also, which picture represents the point cloud and which one the orthomosaic?
point cloud is the one with black back ground
HOLLY HILL PIT 3-8-21_report.pdf (2.0 MB)
Project log file is 7mb this server only allows 4096kb.
how do you suggest to upload?
There are a lot of uncalibrated images (460 out of 720 images calibrated (63%)) which means these uncalibrated images are not taken into account for the reconstruction of your project. Take a look here.
You can reprocess and do the following:
- Update your NVIDIA driver as it is outdated. Close Pix4Dmapper, download and install the NVIDIA driver and reboot your device. ​Download the latest driver from this website.
- Select from Menu Process > Processing Options… > 1. Initial Processing > General–>Keypoints Image Scale: Custom–>1/2 (half image size)
- Select from Menu Process > Processing Options… > 1. Initial Processing > Calibration–>Calibration method → Alternative
- Select Process > Processing Options… > 2. Point Cloud and Mesh > Point Cloud → Point Cloud Densification–>Image Scale: 1/2 (half image size)
I’ve downloaded and installed new driver. Currently reprocessing. I understand there are many uncalibrated images but this particular area appears in 5-6 calibrated photos. There are 2 things that puzzle me.
- How can I have point cloud data in this area and then it doesn’t even show up on the ortho?
- How can several calibrated images with this area in it and it still not show up on the ortho?
One of those 4 steps solved the problem.
thank you so much
Thanks for the update! I suggested this kind of calibration because I saw dense vegetation which results in complex geometry. In this link you can find more information.
Glad I helped!
