I am working on a Pix4DSurvey project where I’ve imported multiple Pix4DMapper projects to help with marker and automatic detection.
Everything is working perfectly expect the photo pane on the right. When I click on a marker to edit its location, the photo pane on the right does not update to zoom into the area I am clicking.
It was working earlier but now it is not. Could it be that I am using too much data? It is a fairly large area and I am using multiple point clouds and Pix4DMapper projects. I attached a photo below
Hi @sam.frederickson,
Thank you for reporting this problem.
Can you please confirm the version of PIX4Dsurvey you are using, and if this is happening with any project (old/new, large/small)?
Kind regards,
Daniele
Hi there,
I am using 1.54.2.
I split the project into a smaller one, and the photos were working, but as soon as I imported our linework from a previous Pix4DSurvey project it stopped working. I attached a photo of the project area.
Thank you for the additional information and screenshot.
Can you please tell me if the same issue happens with PIX4Dsurvey 1.56.0?
Daniele
