Hi, When will the flight facility pix4d capture Matrice 100.
Hello Orkun,
Our developers are working on the integration of DJI Matrice 100 on Android operating systems.
DJI Matrice 100 is expected to be compatible with the latest version of iOS Pix4Dcapture as it supports SDK3. However, it has not been tested yet and it is not possible to select the drone from the drones list. You should select the drone that has the same connection mode as DJI Matrice 100. For example, if DJI Matrice 100 is connected through Wi-Fi to the device, then you could select Phantom 3 Standard. Otherwise, if it is connected through a USB cable you should select a drone using the same connection type.
