This issue should be solved in our latest version 2.1.58?
Is it the version you are using?
You can download it from here if needed: https://mapper.pix4d.com/download/
Currently using 2.1.58 and have the same issue.
Hi Paul,
Have you generated the DSM again after upgrading to 2.1.58?
The old DSM should be replaced with the new DSM that does not contain the deleted points.
I’m seeing this in version 2.1.61.
Hi John,
Have you tried with our latest version of Pix4Dmapper (2.2.22) that you can download here:
I have, same results. Do I need to reprocess the job with the new version of the software? I removed the 3_dsm_ortho and generated volumes.
Same Problem here
v2.2.25
Big pain!
Hey guys, I had the same problem, and I realized I had to run step 3 and then my volumes were correct.
Max.
Hey, I still have this problem!
Are you saying that I need to move those points i dont want to deleted points and then run step 3 processing again? That’s a hassle. Using version 3.1.23
