Hello, my processing is giving an error when generating the DSM.
The message appears (Number of points retrieved by provider is different than asked.)
I already tried changing the settings in the Calibration and Point Cloud steps.
Here is the processing log.
2023-05-07_20-09-25.zip (466.1 KB)
I’m getting the same error with matic 1.45.0.
I’ve also see the same message with this version.
I reinstalled the latest stable version (1.43.2) and processed the DSM without issue.
Andrew,
Can you share the windows installer file with me? I went from (1.39) to (1.45.1) so i cannot download (1.43.2). I’m hoping I can open my 1.45.1 project in the 1.43.2 version> 1.39 doesn’t let me.
Hi @xzamora
All the installer files of the past versions can be found in Technical release notes - PIX4Dmatic.
If you still have an issue opening the 1.45.1 project in 1.43.2, please feel free to attach the log file for us to troubleshoot further what the cause is. ![]()
You can follow this article to export the log file: How to export log files - PIX4Dmatic
Always remember to have the project folder and the dataset’s folder on a local disk/drive (typically C:/ or D:/)
I hope this helps!
Rosana (she/her)
I’m getting the same issue with vr 1.45.1, and it solved when I used a lower version 1.43.2
I was told by support team to install 1.46.0 version released 2 days ago. I am doing it now. I hope this issue resolves with the latest release.
Hi all,
This error
is fixed in v1.46.0.
Here are the bug fixes and improvements
- Fixed issue with perpetual educational license handling
- Fixed an issue where the DSM was failing for certain projects
Please ensure to do a complete uninstall of PIX4Dmatic and download the latest version in our Technical release notes - PIX4Dmatic or here: Download PIX4Dmatic photogrammetry software
Here is how to do a complete uninstall:
- In the Windows Search, type Add or remove programs .
- Scroll to find PIX4Dmatic and click the application.
- Click Uninstall .
- On the path where PIX4Dmatic was installed (default is C:\Program Files\Pix4Dmatic ), ensure this folder does not exist anymore. If it exists, DELETE this Pix4Dmaticfolder.
- In C:\Users\Your Username\AppData\Local\pix4d , ensure the folder Pix4Dmatic does not exist anymore. If it exists, DELETE this Pix4Dmatic folder.
- In the Windows Search type regedit and search for the folder stored in the path: HKEY_CURRENT_USER\Software\Pix4D and ensure this folder does not exist anymore. If it exists, DELETE this PIX4Dmatic folder.
- Restart the computer.
- Reinstall the latest preview version (v1.46.0) of the software: Technical release notes - PIX4Dmatic
Rosana (she/her)
