Anytime I process images from my DJI P4 multispectral I have to manually enter the Green, Red and NIR band. Can anyone help me on what could be the issue on why the software does not recognize the bands?
Hello @wyatt.young, The reason that the software is not able to detect the camera model is because the metadata on the images are not correct. I recommend you to updates the firmware of the drone and camera and see if that helps to resolve the issue.
Hello, I did update the firmware on the drone and i am still receiver the "Error e0024: the parameters of the camera model are not valid. Error: Set R2 between -focal[px] and focal [px].
This electronic message contains information generated by the USDA solely for the intended recipients. Any unauthorized interception of this message or the use or disclosure of the information it contains may violate the law and subject the violator to civil or criminal penalties. If you believe you have received this message in error, please notify the sender and delete the email immediately.
Please reach out to the camera manufacturer and see if they are able to help you because the issue is related to the camera EXIF.
