Hello. I downloaded Pix4Dmapper-4.8.4
I am not able to install it (Windows 8.1 64bit)
How can I find an older version to instal
Thanks a lot in advance …
Hi @yiannismastoris,
welcome to the Pix4D Community ![]()
You can access PIX4Dmapper version 1.1.46 from here.
Please let me know if this helps you.
Cheers
Thank you so much
I installed it normally
I am not able to open p4d files. It opens only some tutorial files.
I guess I have to request a free trial
Στις Τρί 25 Απρ 2023 στις 5:24 μ.μ., ο/η Daniele Lecci via Pix4D Community <notifications@pix4d.discoursemail.com> έγραψε:
You are probably logged in with the Pix4D Discovery license/mode. This is a version with limited functions. For more information: PIX4Ddiscovery / Discovery mode.
Please follow the following directions to get full access to PIX4Dmapper software:
At this point, you should be able to re-run the project with the desired processing options.
Cheers
