Hi all,
I was wondering if the surface model generated with Pix4D fields can be used to create a detailed land leveling project.
With also the ability to give to the tractor information on how much soil has to be moved from a part of the field to the other.
Thanks a lot for your time
It can be used for this yes. Trimble software needs the DSM in a specific format called MultiPlane.txt, we are currently investigating if we can export this. Other softwares for field levling are able to import XYZ files which can be easily derived from the DSM like OptiSurface.
Thanks a lot.
And to do this you suggest to use the feature for accurate processing of the orthomosaic? Or the fast processing is enough?
The accurate processing as it provides a much higher resolution DSM.
