Pix4d Fields - Trimble Compatible
I have seen that Pix4d fields is compatible with John Deere in regards to doing spot spraying with a JD tractor/sprayer.
Is Trimble able to do the same process?
Thank you in advance
The trimble display will work with shapefile export. It depenbds on the type of terminal how you have to organise files so its recognised.
Do not select zero rate zone upon export and:
CFX 750, GFX1060, GFX1260, FMX 1000, TMX-2050
For the machine to read it, the files comprising the Shapefiles (.shp) must be on a USB drive within two folders:
  • The first folder should be named: AgGPS (maintaining capitalization).
  • Within that folder, another folder should be created named: Prescriptions.
  • Inside the Prescriptions folder, the files should be loose.
GFX 750, GFX 350
It supports both shapefiles and ISOXML.
  • The first folder should be named: AgData (maintaining capitalization).
  • Inside the Prescriptions folder, the maps should be loose.
