We are excited to announce the release of PIX4Dfields 2.5, our last release for this year and it is a big one!
We did a complete overhaul of the Zonation feature and migrated it to the new Targeted Operations workflow. This allows to create grid based variable rate and spot spraying maps from vegetation index data as well as MagicTool detections. Now its way easier to create green-on-brown spot spraying from vegetation index data.
The second major feature is a tight integration into the John Deere Operations Center, so you can easily upload aerial and crop health maps, boundaries and prescription maps to your OPS Center account directly from PIX4Dfields.
We also added the ISOXML export format for ISOBUS compatible machines, allowing for the export of prescription maps to a wide range of agricultural machines.
There are many more additions, read more about it in our release blog post!
๐๐๐ฐ ๐๐๐๐ญ๐ฎ๐ซ๐๐ฌ
Targeted Operations: Zonation (pre-fill grid based on an index layer)
Upload directly to John Deere Operation Center
Export operation layers as ISOXML prescription maps
High-resolution snapshot export
๐๐ฆ๐ฉ๐ซ๐จ๐ฏ๐๐ฆ๐๐ง๐ญ๐ฌ
Targeted Operations: Undo and reset buttons
Targeted Operations: Ability to assign a rate to all empty cells
Targeted Operations: Replaced eraser tool with the ability to paint with the empty rate
Targeted Operations: SHIFT hotkey for switching between the selected rate and the empty rate
Targeted Operations: Support for pre-filling the grid using point annotations
Magic Tool: Improved performance with the help of user-submitted data
Support for Yusense MS600, AQ600 and MS400.
Support for Wingtra RGB61.
Support for Wingtra A6100.
Support for DJI Mavic 3T (RGB, Thermal)
Support for DJI H20T (Thermal)
Support for DJI Mavic 2 Ent. Advanced (Thermal)
Support for DJI Mini 2.
Support for DJI Mini 3 Pro.
Support for DJI M30 (RGB).
Support for MAPIR Survey3W.
Support for Sony Alpha 1
