We have 12bit and 16bit DMC2 250 camera images.You can look at the attached photo.(cameras.jpg)
With pix4d, we have a lot of problems when we want to make process with Large Images.
First of all, we have problems defining camera parameters.We can’t enter the values we want.Appendix you can see our camera parameters.(camera_parameters.jpg)
Another addition is the pix4d camera settings screen.(pix4d_camera.jpg)
Second, we have 16bit images added to the program when I send the results report.The orthomosaic preview result is black.What could be the reason for that?(report.pdf)
Another problem is that we get error when we add 12bit photos to the program.(12bit_images)
We get the same error when converting photos to 8bit and add to the program.What do we do to process 12bit photos?
Third, we can get a result when we convert the 16bit images to 8bits and process them, but the result is not good because we can’t enter the camera parameters properly.
At the same time, we get an error in the mosaic editor as I sent in the attachment.(mosaic_editor_error.jpg)
