Phantom 3 not turning around
If I make a fight plan in the app, is it correct that all my photo’s are aimed to 1 location instead of the drone turning to make pictures from all angles?
Hi Michiel,
Yes it is indeed correct, the drone translates when doing a grid mission.
Therefore, if you change the camera angle and make it oblique, all images will have the same orientation.
It makes no difference when the camera is set to vertical though.
