Phantom 3 advanced flight mode
Which flight mode(P,A,F) should I use with my phantom 3 advanced with pix4dcapture
Hi Marco,
To fly the Phantom 3 Advanced and most of the DJI drone supported by Pix4Dcapture, the toggle switch on the remote controller has to be set in the F position.
The switch position is an item checked in the takeoff checklist and you won’t be able to start a mission if it is not set in the correct position.
In the case an unexpected behavior occurs during the automated mission, you can change the toggle switch position to A or P to take manual control of the drone.
You can find below a description of the FAP mode from the manual of the P3A:
