error after the last DJI update.
I have flown the capture Pgm successfully but now get FAP error in final check. I have switched to WiFi but it did not clear the error. Can’t fly the mission now that I’ve paid for the desktop software. Tks
Hi James,
Did you make sure to have selected the Mavic Pro in the list drone before starting the mission?
Actually the F.A.P. is specific to other DJI drones. You should put the P.S. switch button of the controller in the P position to activate the automatic flight mode.
In case you have any doubt, you can refer to our Getting Started: https://support.pix4d.com/hc/en-us/articles/202557269
