Trying to process a project with the DJI P1 however am having issues when using the XML file setup.
I have uploaded a XML file for the P1 that i found on a discussion on here.
However when i then upload the images i am still getting the issue that says Camera is Not Supported.
Can anyone help me with this and direct me to how i might start to get this project underway.
Could it be that the account is in trial mode and therefore is affecting my ability to utilise this process?
Any help would be appreciated.
I ahve attached the XML file below
File.xml (1.3 KB)
Thank you very much for the explanations provided. I definitely had a miscommunication problem with my previous message, I am very sorry for this inconvenience.
If the drone is Phantom 1, we don’t support it.
If the drone is a Zenmuse P1. Indeed, there is a workaround for this type of case. Attached is the XML file that should allow working with it. In the future, you can reference this article in order to generate the file yourself.
What to do when a camera is not supported in Pix4Dfields
Let us know if you have any issues. I look forward to your response.
ZenmuseP1_35.0_8192x5460.XML (994 Bytes)
