Hi, this app Is the best, but still does not make polygons that ends up resulting in unnecessary photos.
However, I have been experiencing random problems with photo overexposure. Then I make other flights and the photos are normal. What to do. Thank you very much for the support.
Attached some photos where the variation of exposure time varies between 8333/1000000 for a good photo and 8333/500000
Hi Roberto,
thank you for attaching some sample images. This way it is easier to understand what kind of issue you are facing.
Camera settings are automatically adjusted in order to capture the dataset that is optimal for the reconstruction. In most cases there are no issues with automatic setting but in your case try to adjust the settings in the DJI GO app. Changing the camera settings in DJI GO might be effective in the app but it is not guaranteed as it was not extensively tested. It also depends on the drone, camera and type of mission. The aperture and exposure time are automatically set by DJI but can be adjusted and should be taken into account. These settings impact the sharpness of the image.
More can be found here: 203204339
