Orthomosaic Export
I am trying to export my orthomosaic to AutoCAD Civil 3D 2016 as a GeoTIFF but after the processing is complete the only files that are available are .tfw and .prj and not .tif. Is there a setting I need to change to correct this? Any hel
p would be appreciated!
Hey GCG ASSOCIATES INC,
Your processed tif orthomosaic output should be in a folder similar to this:
 your_project\dsm_ortho\mosaic\your_project_transparent_mosaic_group1.tif
You can access to that folder above either manually navigating to it or under Process tab then Open Results folder.
Also since it is an RGB camera, under Index Calculator you don’t need to check the reflectance maps unless you want each Red, Green and Blue band separately. Reflectance maps are either for Multi-spectral cameras or Thermal cameras.
