we want to model an oil tank, diameter +/- 70m. Inside and outside. What strategy is suggested to capture the inside successfully (open from above) and be able to match it with the outside.
For exterior I will fly at approx 40m with camera at 45deg.
If the inside walls of the tank are visible from above and the texture is not uniform we would suggest a double grid mission. Regarding the exterior flight it is recommended to take one image every 5-10 degrees to ensure enough overlap, depending on the size of the object and distance to it. Shorter distance and larger objects require images every less degrees.
SO how does flying a grid scan the sidewalls of the tank? Are you able to select the cylindrical model and have the camera facing outwards or maybe the helix? This would allow a lot of use to scan the inside of tanks for inspections and reduce the need for manlifts/scaffolding. Is this possible?
