hello
i wanna generate quality report after adding the GCPS but it keeps failing, this is the error i get:
[Warning]: Warning w9020: GDAL Error <4> V:/2025_agadir souss massa Amenagement/agadir finale/1_initial/project_data/thumbnails/459_DJI_0444_512.jpg: No such file or directory
[Warning]: Warning w9020: GDAL Error <4> V:/2025_agadir souss massa Amenagement/agadir finale/1_initial/project_data/thumbnails/459_DJI_0445_512.jpg: No such file or directory
[UI]: Generate Quality Report clicked.
Processing: Substep Report generation started.
[Error]: InitialProcessing: cannot compute the mean resolution. Not enough calibrated 3D points.
Processing: Read keypoints.
Processing: Load point cloud
[Error]: Load point cloud: not enough tracks!
[Error]: Point cloud loader: Initialisation failed with error: [Load point cloud: not enough tracks!]
[Error]: Load point cloud failed!
Processing: Compute number of matches.
Processing: Substep Report generation finished.
Processing: Substep Save parameters started.
Processing: Substep Save parameters finished.
[Error]: Error e0900a: Cannot export point cloud in LAS/LAZ format. There are no points.
knowing that the gcps are in fact covering the zone, and exists in the folder in which the error says that there is no such files. also the project is made out of 6 seperated projects for which the initial treatment is done. what should i do in order to get the report project so i can generate the cloud points.
