Sounds good. Thanks for replying. Do you have any guess on when the M30 may get supported, or do you have a xml file we could use currently?
You can find the xml here https://support.pix4d.com/hc/en-us/articles/360039273312-Your-camera-is-not-supported-at-this-time-PIX4Dreact
Unfortunately, I can’t give any date on the release.
I have a DJI M30. Pix4dmapper support this camera?
Hi Marco,
Yes you can process the M30 in PIX4Dmapper as it’s camera agnostic.
Hi @Jose.Arnaudo Does PIX4D Cloud support DJI M30? Also, can we incorporate GCP values in the cloud processing? Thanks
Yes PIX4Dcloud supports the DJI M30 RGB and you can incorporate GCPs, https://support.pix4d.com/hc/en-us/articles/115005242946-How-to-use-GCPs-for-processing-on-PIX4Dcloud.
Noted. Can we use Pix4D Matic instead of pix4d mapper for the workflow in the aforementioned link? Is there a link that specifies the steps? Thanks again
Yes you can also import GCPs into PIX4Dmatic, you can find information here,
https://support.pix4d.com/hc/en-us/articles/360038397752-Tie-points-GCPs-CPs-import-format-PIX4Dmatic.
Hi. I have dji m30t thermal images. And i am trying to make land surface temperature map at arcgis. But i cant process images in pix4d as temperature only in RGB. Tried some corvertion tool but results are not true. So can you help me about converting images or any other way?
