Hi, Is it possible to select more than one area to process?. In the case of a golf course there are many different areas within the polygon, I would like to draw different areas, eliminating the houses and private lots from the rest of the process. I know how to select a processing area but not sure if it is possible to do it with different areas,
Thanks,
Franco Santoro
