Multiple boundaries on one project
I flew a 150 acre property that had 4 separate fields in it. When I process it, I can only seem to draw boundaries for one field. Is there a way to draw boundaries for all 4 or how should I go about it? Thanks.
-Adam
Hi Adam,
You can either draw a separate boundary for each field, this will allow you to generate outputs for each field.
If you manage 4 fields together, you need to add “sub-polygons” , https://support.pix4d.com/hc/en-us/articles/360000891603-Field-boundaries-and-obstacles-PIX4Dfields-
José
