There are more similar topics, but all can be merged together in one feature - divide processing in one project with multiple processing areas. You can run step 1 and starting from step 2 you will be able to choose, which processing areas to proceed (saved separately)
Then you will be able to create several meshes and total level detail of greater area will be much much higher.
