Mavic 2 Pro image geolocation
Has anyone else had problems importing images from a Mavic 2 Pro. (WGS84 input)
Pix4D seems to have incorrectly converted the degee/minutes/seconds info to decimal degrees.
First Image Example;
RAW                 LAT -26; 37; 36.1553469857170     LONG 120; 14; 26.266025085700    ALT  478.8
CONVERTED   LAT -26.62671                                 LONG 120.240629                            ALT 478.8
PIX4D               LAT -26.6096662975913                 LONG 120.240629451413                ALT 474.799987792969
As you can see only the latitude is incorrectly converted.
Hi Blackham,
I think that you should have a look on this post. It should help you to solve your issue:
Pix4D-Mavic-2-Processing-Issues
A workaround is proposed in the second comment (“Official comment”).
