Hello, I use pix4d trial 15 days to test on my institution project latest version, I use Mavic 2 Pro with drone deploy for images acquisition
I saw weird result as long as i input the images on to the pix4d
the detection for projection and coordinate is correct (WGS84 as we use geographic geotagging), BUT, the positional on map view is wrong
there is a gap between my two sub project and images position slightly off to the north, this should be overlap
I attach the screenshoot.
So, I try to process on another software, in my case, Agisoft, for the comparation, and the result is good
so whats wrong? Did I miss something on this?
