Mavic 2 Pro - camera settings and results
I’ve been sorting out a Mavic 2 Pro - it’s no longer a new model - but mine hasn’t been used much - and I’d like to see if I can put it to work.
It’s been a bit of a challenge to figure out the proper settings in Pix4D for the camera. I think I finally have settings that work, but there’s still more correlation than I think there should be.
If someone is still using this drone, would it be possible to share some quality reports with me so I can compare settings? Anything over about 20 acres with GCP’s would be really helpful.
I’d be more than happy to provide samples from mine.
Many Thanks!
Hi @joe.stroup,
The Mavic 2 Pro is in the PIX4Dmapper camera database.
Can you please share your quality report so we can see if the camera is correctly detected?
Daniele
