Dears,
is the matrice 600 pro with x5s compatible with pix4dcapture?
Thanks,
Max
Dears,
Thanks,
Max
It should work as I have flown the M600 with it…unfortunately I don’t have a DJI camera so Pix4Dcapture won’t complete the mission but it does fly to the start point and wait for the camera to snap a photo. I give it a 99% chance of success for you if everything is setup correctly on the drone…and this is pretty darn easy to test, just try it and report back your findings.
Dear Adam
Does M300pro without camera is compatible to fly mapping mission ?
Hello @vomuan, I would recommend you to go through the below support article and you can find the required information,
