Manually Collected MicaSense Image
This is Md Asrakul Haque. I am currently working on a Ground based sensor project where I am taking multispectral images with a very low altitude (1.8 m ) via Micasense attaching with a rail based structure instead of using Drone. But I am facing several problems like “No Path Reference” , " No Calibrated image" and so on. Moreover I had to capture images plot by plot with a series of flight. Although Frontal overlapping was more than 75%, but being covered by a straight flight, no sidewise overlap occurred laterally. Now I urge your precious guidance on enhancing the further precedings .
Thank you so much
The images have no GPS points so that makes it considerably hard to match. Is this for Mapper or Fields? Have you tried with the GPS on?
