Hi Folks - New to Pix4D / Photogrammetry.
What is the preferred setting in the Double Grid Advanced for “Look at Grid’s Center”? Flying a Mavic 2 Pro. The documentation states the difference between “Yes” and “No”, but I’m not sure which is the recommended setting.
From the documentation:
Look at grid’s center
Defines whether the drone should be oriented towards the center of the mission when taking pictures, Yes, or not, No (default). The point of interest should be the middle of the area to map.Important: This option only makes a difference in terms of reconstruction if the camera is tilted. Indeed, it can for instance help to capture information from facades of objects.
Thanks!
