hello there,
please tell the development team that when creating an application it is really annoying that the calculation starts after every marked field (with large ereas). it is better if you can mark a few fields at the same time that you want or don’t want, rather than having to recalculate for each individual field! Thanks
Thank you for your comment. To clarify are you referring to the Magic tool and the possibility to re-use the mark between fields?
