Adding Prescription Value to Magic tool Annotation/Shapefile
I am trying to complete spot spraying applications using the Magic tool In pix4D Fields. I have created the annotation area around the weeds in the field and have exported the annotation as a shapefile to the Equipment. Is there a way to add a prescription rate to that shapefile? The implement is looking for that value for the application and not seeing it. An example would be the information in a zonation prescription but in a shapefile the Magic tool Created.
Was wondering if anyone would know how to add the application value to the shapefile, or this could be added to the feature list?
Hi, gundiwindi.farms,
This issue will be fixed in the next release of PIX4Dfields this month.
In the meantime, you can use QGIS to add the missing attribute to the shapefile. Here is how:
Thank you Julius!
It’s impressive the amount of information we are getting in the community and the quick responses from the team!
Im looking forward to trying out the new update.
