Latest Matic Version (1.76.0) - Tiled Mesh ?
For the past 2 years we have been making the Mesh in Matic and exporting the 4 required files to upload to Pix4d Cloud.
.obj + .mtl .jpg + offset.xzy.
Our latest run of some data, we are now getting a “tiled” output for the mesh within its own folder, however, depending on the size of the job, the number of tiles vary.
Understand if this is a new way forward, but how do you upload such mesh data to the cloud ?
Thanks !
Hi jhawkins,
This is our “scaleable mesh” option which is the default. However, you can change the mesh back to the “standard” option.
The other item to mention is that you can always use our Share to PIX4Dcloud feature within Matic. This will let you upload already processed results to the Cloud for viewing.
Hi jhawkins,
To add to what Mike was saying, you can upload the high resolution mesh directly from Matic using the Share to Cloud functionality. This will export the full resolution mesh a a 3D tiles asset, with the full LoD. Would that work for you?
yes this is a pain, I re processed 3 projects trying to create a single mesh for upload, and assumed it was a bug. The share to cloud option hasnt and still doesn’t work . If this mesh is better thats great, but can we then need a method that works for the cloud.
@jhawkins and @software6 the best way to upload your mesh to our cloud is to use the “Share to PIX4Dcloud” feature. Let us know how it goes or why you still export from PIX4Dmatic before uploading to PIX4Dcloud.
What issue are you running into when attempting to share to PIX4Dcloud @software6 ?
We just updated to 1.77.1 today and found the the exported mesh .obj is in tiles instead of a single .obj.
I can’t find an option to change from scalable mesh back to “standard” anywhere…
Our clients can’t handle tiled mesh, it needs to be a single file.
Any ideas?
@aus-bd-survey the pipeline we use to generate a mesh has recently changed and the 1.77.1 preview version indeed does not include a way to export a single-tile OBJ file. We are working on adding this option again. Do you know which third-party applications your clients need to import the mesh in use so that we can ensure good compatibility? In the meantime, I recommend you revert to the latest stable release, 1.76 (or wait a few days to use the 1.76.1 patch we are about to release).
GEM4D is one of the main third-party applications, as well as Vulcan for some other clients.
Will there be a fix for this after 1.77.1? or will be we forced to stay at 1.76?
@aus-bd-survey thanks for the info, and I confirm that we are planning to re-implement the mesh export of a single OBJ file as soon as possible. In the meantime, please use version 1.76.1.
Have just installed V1.81 where you have claimed to have fixed this issue. it is true, the option to export out a single jpeg sort of exists, but the results are terrible compared to the outputs of 1.76.1
the entire output is dictated by the LOD slider, you cannot have a high-res image with low triangle mesh, once you dial up the LOD to bump up the triangle count, the resolution increases until Matic just makes another jpeg ignoring the selection to make a single image, and its trial and error. this isn’t what we wanted. give us back the ability to change the triangle count ourselves and export a single 16k image… how it was. This is a backward step Pix4D
Same issue. Need to be able to select number of image tiles. This is Maptek Pointstudio.
Just tried updating to 1.84 and re-ran a flight through it.
As @mining.monitor mentioned above - there still is no real solution to exporting a single image.
Even when playing with the export slider to be able to get an export with 1 image, the way that image is created is different than before - and results in poor texture-mapping in other software
The multi-image output being even worse somehow…
(trying to attach example screenshots, but keeps giving me an error, try this link instead: My Gallery — Postimages)
@Rhea_Garratt @Mike_K
Hi Rhea / Mike, do you have any update on this by any chance?
:slight_smile:
Bump!
Still chasing some feedback around this issue.
@aus-bd-survey Thanks for following up, and we understand that the recent change to the mesh generation pipeline is still causing disruption. The decision to move to the multi-tile OBJ format was a necessary step for the future scalability and quality of our mesh processing. It seems that the vast majority of modern, professional engineering and AEC (Architecture, Engineering, and Construction) software has supported managing complex scenes with multiple OBJ and MTL files for many years. This multi-file approach is the industry standard for handling large, detailed 3D models. I reached out to BasRock (GEM4D) and Maptek (Vulcan) about supporting our multi-tile meshes, and I will keep you posted. Cheers
Have tried version 2.1, still the same issues, will be using 1.76.1 until this is fixed.
Hi @Rhea_Garratt ,
I wasn’t aware that I can Share the Results from Pix4DMatic to Pix4DCloud; by the way, I think we could ask for two slight improvements:
  • UI: Be able to Look for a known Site, as in Pix4DCloud. We have too much Datasets and Folders, so the Search Option is being more important as time passes
  • UX: Be able to “push/autosolve” the CRS issue, whenever we are overriding the results of an already existing dataset
P4DM_toP4DC-ezgif.com-optimize
By the way, the version 2.5.4 still shows the issue of .jpg tiling with a single .obj, so other users could be still affected if their final software doesn’t allow tiled meshes and/or textures
Giancarlo
