How far away is it before we can import a KML file into pix4D Capture?
Google Earth is so outdated in our area, it is almost useless as a background image.
Please make this a priority and advise how long it will take?
Thank you.
Thank you.
Hi Anthony,
I added your vote for the feature.
To get the latest updates about this specific feature I recommend you to follow How to import an area of interest polygon in the Pix4DCapture app IOS version? community post.
In Pix4Dcapture, if you go into your settings and select Map, you can change the preferred basemap provider if you do not like the Mapbox default. Our Android article on the topic will help guide you through this process. The Android interface looks different but the concept and feature is roughly the same. This Article is located HERE.
