Importing KML file into Iphone
Gooday I need to import a KML file on PIX4D Capture to do a pre flight plan on exact area, unfortunately when you look on google earth you cant get a proper location to fly over, a new section that has been built
Hi guys,
Please could you advise on this asap.
Need to know what is happening here.
Regards
Stieg.
Hi Stieg,
You can only import the .kml file in the android version of the Pix4Dcapture app. This feature is not available on the iOS version of the Pix4Dcapture. For more information, I would recommend you to go through our support article on (Android) Import .kml/.kmz file.
Thanks Kapil
Only problem is, I have a iPhone and don’t want to use Android I just hope they can sort out this function as I see their are lots of people asking for this to happen.
Regards
Stieg
