Pix4d Capture (KMZ7KML) IOS
Hello my name is Luis Delfin, I want to know if ther is a way to import kml or kmz files to the pix4d capture to plan a flight.
I hope you can give me information about it.
Regards…
Hello Luis,
You can’t import .kml/.kmz files to Pix4Dcapture app on iOS device. However, if you are using the Android device, you can insert the .kml/.kmz file. To do so follow the steps explained in our support article (Android) Import .kml/.kmz file.
Hello Kapil, thanks so much for your help.
Hello
Goa to loda a map in kml format to pixrdcapture?
