ISOXML 3 Support
A little while back the the support for the isoXML format was introduced. lately if have been trying to load a prescription map into a isobus terminal and it wouldn’t load the map created by pix4d because it wasn’t isoxml version 3 or something. When I use a shapefile to isoxml converter created by Kverneland it does load. I don’t know in what version pix4d exports but I think it isn’t the right version for it to load in the Kverneland isobus terminal.
Thanks,
Hi Dennis, can you let us know the exact terminal where you want to import the map? Maybe it only supports the older version 3 and not version 4.
Pls also attach a working example.
TASKDATA.zip (2.8 KB)
I am using a Kverneland tellus pro terminal with a geospread fertilizer. The file above does work with the terminal but others I have tried don’t. Maybe it could be that it only supports the older format. if so, will there be coming an option to make the prescription map in an older version?
Edit: This file was exported from pix4d as a shapefile and then converted to isoxml using a program from Kverneland.
I experienced the exact same issue as Dennis. Importing the ISO XML (exported from Pix4D) in the IsoMatch Tellus go+ terminal of my Kverneland Geospread furtilizer failed. Same fault code TD. 505: 'Task data version not version 3.
I had the same problem (VICON isomachtellas), but I was able to import it without any problems by opening the XML file in a code editor and changing "VersionMajor=“4"” to "VersionMajor=“3”.
However, it’s a hassle to have to rewrite it every time, so it would be helpful if you could select to export in Version 3.
Also, it’s a hassle to import files for each field, so it would be easier to use if you could provide a single XML with prescription maps for multiple fields.
Sorry if it’s difficult to read as it’s translated from Japanese by Google.
I’m trying to load prescriptinon for variable rate seeding to Valtra T174 and I get “Invalid file” error. I tried to change the SW version from 4 to 3 (major) and nothing - any suggestions?
