I am trying to import prescription maps generated from Pix4DFields into my Agras T40 remote. I managed to import the shapefiles, although it did not read correctly and produced multiple missions for each polygon found within the shapefile. Do you know if there is any solution to this problem?
When I create a prescription map from DJI Terra, it produces a .djitiles file that seems to be the only file type to be read by the remote as a prescription map. Do you know how we could create this file from the shapefile provided in Pix4DFields?
Thanks!
