I would like to create an ISOXML using satellite imagery rather than drone data. If I understand correctly, ISOXML can only be generated as a targeted operations map. Is it possible to generate a targeted operations map in Pix4Dfields using only satellite data (for example, Sentinel-2 or other sources)? Also can I import my own satellite imagery from external tools like ArcGIS or QGIS and still produce an ISOXML file?
Thank you in advance for any guidance!
yes that is totally possible!
- Use the satellite tool to download as scene
- Calculate the vegetation index such as NDVI, NDRE
- Create a Targted Operation - Zonation
- Export as ISOXMl
You can import external geotiff files if they are formated as FLOAT32.
I created an NDVI operation, but whenever I export it as an ISOXML, I keep getting an R0076 error. My drive has plenty of free space, and Iβve checked the official explanation for R0076 without finding any clear cause. Do you have any ideas or suggestions on what might be causing this issue? It is well exported as a GeoTIFF file.
Thank you so much!
can you please create a support ticket so we can look at it closer?
